Hi TMURPH24,
Vapour lock is a thing of the past, nowadays with the fuel pump in the tank and initial priming of the fuel system while turning on the ignition switch, they don't exist.
Pressure is always present in the fuel tank so not surprising if you hear any noise while opening the gas cap.
You could be having a problem with the main relay, the circuit board is known to have bad contacts. Check it out.
SPONSORED LINKS
Sunday, February 19th, 2017 AT 2:16 PM
