Hi butterfly70570,
Seems the clutches are slipping either due to pressure leakages or worn clutch discs. You need to either rebuild or replace the trans.
Did you try to retrieve for Diagnostic Trouble Codes?
Are the trans fluid level correct and the color is bright red?
Where did you send the vehicle for testing and did you try to get a second opinion from another shop?
SPONSORED LINKS
Monday, December 29th, 2008 AT 1:56 PM
