1998 Honda Accord irratic RPM
BOBANDJOANNA
  • 1998 HONDA ACCORD
  • 6 CYL
  • FWD
  • 99,300 MILES
At idle the RPM goes up and down while the accelerator is not touched
Monday, December 29th, 2008 AT 9:04 PM
LORD FARRINGDON
  • 17 POSTS
According to Haynes there could be one of a number of problems causing erratic or loping idle:
vaccum leakage
EGR Valve defective
air filter clogged
fuel pump not delivering sufficient fuel to the injectors
fule pulsation damper faulty
leaking head gasket
timing belt and or pulleys worn
camshaft lobes worn
problem in engine mount control system.
I would check out the first three and the leaking head gasket. In a car of your miileage I wouldn't expect to see timing belt pulleys or cam lobes worn.
Hope this helps :)
Tuesday, December 30th, 2008 AT 6:04 AM
