1998 Honda Accord engine RPM will not go over 3000
LIL_GOTTI_901
  • 1998 HONDA ACCORD
  • 4 CYL
  • FWD
  • 233,000 MILES
I have a 1998 honda accord and when its warm it will go pass 3000 rpm but when it warms up to the half way mark it will not go to 4000 rpm and I have a slow start when pulling off what could cause this
Monday, October 18th, 2010 AT 10:10 PM
Hesitation/Lack of power etc:
Could be caused by one of the following below
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it
Tuesday, October 19th, 2010 AT 1:22 AM
