1998 Honda Accord engine dies
JAYROLX3
  • 1998 HONDA ACCORD
  • 4 CYL
  • FWD
  • MANUAL
  • 240,000 MILES
When I drive I notice the instument pannel and all the warning sybols flicker and the door lock also flicker up and down and than the engine dies. I pull over to the side and re-start the engine again. What is wrong could it be the egnition switch.
Monday, May 4th, 2009 AT 11:59 AM
F4I_GUY
  • 3,302 POSTS
Yes that is a classic case of a failing ignition switch.
Tuesday, May 5th, 2009 AT 6:59 PM
KGOSS_05
If it is a failing ignition switch. For Honda Accords 1997 - 1999 (i think) there was a recall on the ignition switches and you can get it fixed for free at your local Honda dealership. You can go to the Honda owner website and it will tell you more about the recall. Hope this helps!
Friday, May 15th, 2009 AT 6:49 PM
