FIRST YOU SHOULD CHECK FUEL PRESSURE ON CAR COULD BE A BAD FUEL PUMP DEPENDING ON READING ALSO DOES THE CAR NOT WANT TO START SOME TIMES JUST CRANKS IF IT DOES NOTICE FOR A CLICKING NOISE WHEN YOU TURN THE IGNITION ON AND IF THE CHECK EGINE LIGHT TURNS ON [NOT WHILE RUNNING JUST WITH CYCLE OF THE IGNITION] CAUSE IT CAN ALSO BE A MAIN RELAY WHICH IS IN THE CENTER CONSOLE AREA IT CONTROLS FUEL DELIVERY AND IS VERY COMMON TO FAIL
SPONSORED LINKS
Sunday, August 2nd, 2009 AT 1:43 PM
