1998 Honda Accord Acting as if it 'redlines" at 4k RPM
KRIZZEAM
  • 1998 HONDA ACCORD
  • 4 CYL
  • MANUAL
  • 175,000 MILES
So its a manual and when the RPM hits 4k (vtech) it kills the accelerator and bogs down as if it were red-lining. Computer at advanced auto parts said "fuel air"something or other. The guy said maybe throttle position sensor, or some other sensor.
any ideas and how to links would be helpful.
Tuesday, October 26th, 2010 AT 9:34 AM
KHLOW2008
  • 41,814 POSTS
Hi krizzeam,
The most common fault for premature rpm cut is due to a bad or out of adjustment TPS.
Get the TPS check.
Tuesday, October 26th, 2010 AT 2:04 PM
HONDA TECH 1818
  • 536 POSTS
Is the check engine light on? It could be low on oil and the ecm cuts the vtec sytem. Check the oil level make sure is at the full mark.
Monday, November 1st, 2010 AT 1:51 AM
