HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Honda
Accord
Engine
Symptoms
Revs Up
SPONSORED LINKS
1998 Honda Accord
SAMSON OMOROSI
MEMBER
1998 HONDA ACCORD
4 CYL
FWD
AUTOMATIC
196,460 MILES
MY RPM CAN NOT GO MORE THAN 5000 AND WHAN AM ON SPEED THE CAR JARK
Wednesday, October 21st, 2009 AT 11:40 AM
F4I_GUY
MECHANIC
You have a fuel cut. Is the MIL on? If so, get the code read and diagnosed it could be low on oil. Your vtec is not working.
SPONSORED LINKS
Thursday, October 22nd, 2009 AT 8:50 PM
SAMSON OMOROSI
MEMBER
Thanks and godbless
Saturday, October 24th, 2009 AT 12:51 PM
Please
login
or
register
to post a reply.
Related Engine Revs Up Content
1998 Honda Accord Low Rpm
I Recently Had Brake And Fuel Lines Changed From Front To Back. Since Then My Car As Been Stalling From Time To Time. What Can The Problem...
Asked by
mmatj
1998
HONDA ACCORD
GUIDE
Idle Air Control Motor Replacement
The idle air control motor or idle speed control motor is designed to adjust the air flow into the intake manifold at engine idle. Engine idle speed is monitored by the PCM...
1998 Honda Accord Rpm Jumping On Idle
So I Have Two Problems Happening To My Car First, When I Start The Car It Runs Rough And Then Dies. Does This Several Times And Then...
Asked by
jetmech671
1998
HONDA ACCORD
1998 Honda Accord Acting As If It 'redlines" At...
So Its A Manual And When The Rpm Hits 4k (vtech) It Kills The Accelerator And Bogs Down As If It Were Red-lining. Computer At Advanced Auto...
Asked by
krizzeam
1998
HONDA ACCORD
1998 Honda Accord Drop In The Rpm
The Car's Idling Is Set To Around 1000 Rpm, It Usually Runs Normally But Sometimes When I Have Driven Constantly And Start The Car, The Rpm...
Asked by
jaitra.anand
1 ANSWER
1998
HONDA ACCORD
1998 Honda Accord Engine Rpm Will Not Go Over 3000
I Have A 1998 Honda Accord And When Its Warm It Will Go Pass 3000 Rpm But When It Warms Up To The Half Way Mark It Will Not Go To 4000 Rpm...
Asked by
lil_gotti_901
1 ANSWER
1998
HONDA ACCORD
VIEW MORE
SPONSORED LINKS
Vacuum Leak Symptoms
Vacuum Leak
Online car repair manuals
