Engine Mechanical problem
1998 Honda Accord 6 cyl Front Wheel Drive Automatic
car revs to 3000rpms when started and stays there. And when you touch the gas it redlines and stays there
Friday, October 16th, 2009 AT 9:20 AM
KHLOW2008
MECHANIC
Hi davankustomz,
Check the throttle linkage, it could be sticking.
The other item would be the throttle plate. Something could be wedged between the plates causiing it not to close. Remove the air cleaner hose to check. I have seen before air filters disintegrate and bits of it getting stuck at the throttle plate.
