1997 Honda Accord
TDAILEY
  • 1997 HONDA ACCORD
Engine Mechanical problem
1997 Honda Accord 4 cyl Front Wheel Drive Automatic
car will not start. Will start if I spray directly into intake. Suspect fuel pump problem however fuel is getting to rail. How do I check fuel pressure, what tools/equipment do I need and where can I get them
Monday, July 27th, 2009 AT 6:35 PM
  • 31,937 POSTS
HI there,
first check that the injectors are pulsing. You should hear a click when they fire on cranking, you should also be able to feel them when they open, try this first.
Mark (mhpautos)
Tuesday, September 29th, 2020 AT 11:53 AM
TDAILEY
Injectors are pulsing. Just put in new fuel filter, distributor/cap, plugs, wires. Thought problem was oil seal in distributor since fuel system seemed to be ok.
  • 31,937 POSTS
Hi there,
Undo the fuel line at the filter and attach a hose and place it in a jar, crank the engine and check for the fuel flow rate, there should be a port to attach a fuel pressure gauge on the fuel rail, if not you will have to set up a "T"on the fuel rail and hook up a gauge to check pressure, 'you do have good spark don't you and did you check the injectors with a noid light?
Mark (mhpautos)
