1995 Honda Accord Engine over heats
ROLLDOG
  • 1995 HONDA ACCORD
  • 4 CYL
  • 200,000 MILES
I need help on figuring out what I need to do with my car over heating. I changed the thermostat but it did'nt help at all is there anybody that knows any other reason why my car is over heating I sure would appreciate a response. Thank You
Friday, June 13th, 2008 AT 4:52 PM
Have it block and pressure tested-do the block first to pinpoint a combustion leaking into the cooling system or a gas analyzer to sniff for hydrocarbons at the radiator fill neck.
Pressure test: do not do a pressure test if there's leakage at the headgasket this might cause coolant into the cylinders and lock it up or bend a connecting rod if cranked thereafter. The headgasket should be repaired before doing the pressure test.
If the block and pressure test passes check the following: Thermostat, Pressure test the Rad. Cap, Clogged radiator, Fan clutch, Radiator electrical fan, collaspe hoses, water pump.
Friday, June 13th, 2008 AT 4:56 PM
