1995 Honda Accord 2000 RPM
ARMADILLO54
  • 1995 HONDA ACCORD
  • 4 CYL
  • MANUAL
  • 160,000 MILES
When i'm driving my accord it make a slight shaking when the rpm's are close to 2000 and no other point.
i've changed the starter distributor cap the rotor and spark were changed not that long ago. I had to change the starter because I waited a long time to change the rotor that was bad. I would start the car and it would hesitate but it wolud start and after so long it stopped. So after I replaced the distrubtor cap and rotor and starter, it started fine and now between 2000 rpms it makes a noise and twice now the car slowly started shut of and the check engine light will come on. What can the problem be?
Tuesday, July 8th, 2008 AT 7:43 PM
KHLOW2008
  • 41,814 POSTS
Hi armadillo54,
When the check engine light comes on, a scan would lead you to where the problem could be.
Get the scan done first.
I suspect the EGR system is malfunctioning.
Wednesday, July 9th, 2008 AT 2:56 AM
