1994 Honda Accord high idle
EUGENEPETER
  • 1994 HONDA ACCORD
  • 4 CYL
  • FWD
  • MANUAL
  • 15,000 MILES
When I first start my engine the idle performs normally. However, during summer ambient air temperatures as the engine gets warmer after running for awhile the idle speed increases to anywhere from 2000 to 3000 rpm. If I turn the car off and restart after 5 or 10 minutes after it has been ilding high it idles even higher until I've run it for a few minutes. THe engine then settles back to it's normal high idle of 2 to 3 thousand rpm. I do not have this problem during cooler times times of the year. Then it idles at it's normal engine speed of about 900 rpm. Can you tell me from this what sensor is bad?
Tuesday, June 2nd, 2009 AT 3:35 PM
KHLOW2008
  • 41,814 POSTS
Hi eugenepeter,
For temperature to affect the idling, the most likely would be the Intake Air Temperture Sensor.
If it is due to others, the Engine Coolant Temperature Sensor, Idle Air Control valve, Cold start valve and coolant level should be checked.
Wednesday, June 3rd, 2009 AT 1:58 PM
