HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Honda
Accord
Engine
Symptoms
Revs Up
SPONSORED LINKS
1993 Honda Accord RPM
MARV777
MEMBER
1993 HONDA ACCORD
4 CYL
2WD
AUTOMATIC
147,000 MILES
Could a bad water pump create a vacuum leak making it impossibile to adjust the rpm on my engine?
Sunday, December 7th, 2008 AT 11:33 AM
BRUCE HUNT
MECHANIC
No. What is the engine doing? Is it surging up and down?
SPONSORED LINKS
Sunday, December 7th, 2008 AT 8:38 PM
MARV777
MEMBER
Correction to my question. Should have been as Follows:
RE-!993 Honda Accord 4 cyl automatic
Could a bad brake master cyllinder create a vacuum making it impossible to adjust the rpm on my engine?
Sunday, December 7th, 2008 AT 11:17 PM
BRUCE HUNT
MECHANIC
I would still respond with no but what is the engine rpm doing?
Monday, December 8th, 2008 AT 5:14 PM
MARV777
MEMBER
Running too fast
Monday, December 8th, 2008 AT 6:02 PM
BRUCE HUNT
MECHANIC
Running too fast at idle when cold or all of the time?
SPONSORED LINKS
Tuesday, December 9th, 2008 AT 11:10 PM
MARV777
MEMBER
All of the time
Tuesday, December 9th, 2008 AT 11:25 PM
BRUCE HUNT
MECHANIC
Check for a vacuum leak.
Friday, December 12th, 2008 AT 8:03 PM
Please
login
or
register
to post a reply.
Related Engine Revs Up Content
1993 Honda Accord Erratic Shift,shift At Hi Rpms
Got D4 Light Blinking Chk Codes Got #8, Chk Connection And Connetor Was Burn, Replace It Then Chk Tcm And Was Burn Also. Send The Tcm For...
Asked by
quiquepr69
1 ANSWER
1993
HONDA ACCORD
GUIDE
Idle Air Control Motor Replacement
The idle air control motor or idle speed control motor is designed to adjust the air flow into the intake manifold at engine idle. Engine idle speed is monitored by the PCM...
My Engine Runs Too Fast, How Do I Adjust The Rpms?
My Engine Runs Too Fast. How Do I Adjust The Rpm?
Asked by
marv777
1993
HONDA ACCORD
1993 Accord Se Rpm Engine Issue Possibly
Hi, Car Has 127500 Miles, Automatic, 4 W Drive, When I Drive It Drives At 3000-3500 Rpm At 60 Mph Is That Too Much? If So What Is Wrong...
Asked by
mnheart
1 ANSWER
1993
HONDA ACCORD
My Car Is Idling Erratic When I'm In Park And Also The...
My Car Is Idling Erratic When I'm In Park And Also The Lowest My Idle Will Go Is 1100rpm. This Is Even After Adjusting The Idle Screw To...
Asked by
Anonymous
1 ANSWER
1993
HONDA ACCORD
2000 Honda Accord Engine Rpm Fluctuation
I Parked My Car And Went On Vocation Every Thing Was Fine Until Then After 20 Days When I Came Back And Started My Car It Was Running Ok On...
Asked by
iamfurqan
2000
HONDA ACCORD
VIEW MORE
SPONSORED LINKS
Vacuum Leak Symptoms
Vacuum Leak
Online car repair manuals
