1993 Honda Accord Car wont start
CURBY123
  • 1993 HONDA ACCORD
  • 4 CYL
  • FWD
  • MANUAL
  • 266,000 MILES
I stopped at a red light when I took off my car died. The timing belt is turning and the igniton coil has no fire coming from it what should I change or check first.
Saturday, September 20th, 2008 AT 3:51 PM
KHLOW2008
  • 41,814 POSTS
Hi curby123,
If the distributor rotor is turning, it is not a timing belt problem.
You need to check for power supply to distributor Black/Yellow wire with ignition switch turned on.
Test the ignition coil primary and secondary resistance. If out of specs, replace coil.
If above ok, the ICM could be faulty.
Tuesday, September 29th, 2020 AT 1:21 PM
