HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Honda
Accord
Engine
Symptoms
Not Running
SPONSORED LINKS
1993 Honda Accord
PATRICK BORRETT
MEMBER
1993 HONDA ACCORD
Engine Performance problem
1993 Honda Accord 4 cyl Front Wheel Drive Automatic
i have a 93 honda accord it will crank over but will not start do you think it might be the fuel pump going bad what do you think
Wednesday, September 16th, 2009 AT 9:48 PM
KHLOW2008
MECHANIC
Hi patrick borrett,
Here is a link for you to check what might be wrong. If you require additional information, post reply and I will get back to you.
https://www.2carpros.com/kpages/first_things.htm
SPONSORED LINKS
Tuesday, September 29th, 2020 AT 1:14 PM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
1993 Honda Accord Car Will Not Start
1993 Honda Accord Manual 240000 Miles I Blew The Valve Gasket And I Changed That And The Spark Plugs, Spark Plug Wires...
Asked by
stephanie123
1993
HONDA ACCORD
VIDEO
How to fix an engine that wont start
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
My Engine Will Not Start Up And Run What Is Going On?
I Tried To Use The Starting Fluid To Get My Car Started But It Still Will Not Start. Any Suggestions?
Asked by
stephanie123
1993
HONDA ACCORD
1993 Honda Accord Car Wont Start
While Headin Home From Work Car Suddenly Sputtered As If I Was Out Of Gas, But No 1/2 Tank Of Gas. Pulled Over And Tried 2 Restart, Engine...
Asked by
Honda35
1993
HONDA ACCORD
I Was Driving My Car When I Noticed That The Speedometer And The Rest Of The Gauges Were Fluctuating And Then Stop Working All Together....
Asked by
tunerGuy
1993
HONDA ACCORD
1993 Honda Accord Car Won't Start Periodically Unless...
The Engine Won't Turn Over. It Wants To But Doesn't Seem To Get That Spark To Fire The Engine. Once I Put Jumper Cables On It It Turns...
Asked by
paulie3
1993
HONDA ACCORD
VIEW MORE
SPONSORED LINKS
Crankshaft Sensor Symptoms
Crankshaft Sensor Replacement
Online car repair manuals
