HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Honda
Accord
Engine
Symptoms
Not Running
1992 Honda Accord
XCALIBUR
MEMBER
1992 HONDA ACCORD
4 CYL
FWD
AUTOMATIC
300,000 MILES
Not getting fire. Motor turns over but does not start
Saturday, June 27th, 2009 AT 7:48 PM
KHLOW2008
MECHANIC
Hi xcalibur,
Did you check if there is power supply to the distributor?
Are the dash indicator lights showing when ignition switch is turned ON and whelie cranking?
Is the distributor rotor turning? It could be a bad timing belt?
SPONSORED LINKS
Wednesday, September 30th, 2020 AT 10:08 AM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
Engine Won't Start After Replace
I Recently Replaced The Cylinder Head, Water Pump, Timing/balance Shaft Belt On My 92 Accord. I Also Added A Cold Air Intake And High...
Asked by
shawnee99
1992
HONDA ACCORD
VIDEO
How to fix an engine that wont start
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
Car Will Not Start
1992 Honda Accord, 4 Cylinder, Manual, 250,688 Miles. I Have Fuel Pressure And Spark, Injectors May Not Be Working. Any Help...
Asked by
cape breton
1992
HONDA ACCORD
1992 Honda Accord Won,t Start
I Have A 1992 Honda Accord It Turnover But Won, T Start I Put A New Distributor And Coil Cap Fuel Pump Wires Plugs
Asked by
randy bonds
1992
HONDA ACCORD
Hot Days Occasionally Will Turn Over But Will Not...
92 Accord, New Fuel Pump Good Battery And Lots Of Spark. On Hot Days Occasionally Will Turn Over But Will Not Start But If Left To Cool...
Asked by
Wade411
1992
HONDA ACCORD
1992 Honda Accord Car Won't Start Sometimes
My Car Just Won't Start Sometimes. I Let It Sit For 20 Mins And Go Back And Then It Starts Right Up. It Is Almost Like It Is Not Getting...
Asked by
janetbly
1992
HONDA ACCORD
VIEW MORE
SPONSORED LINKS
Crankshaft Sensor Symptoms
Crankshaft Sensor Replacement
Online car repair manuals
