1992 Accord, 137,000 mi, 5 spd, fuel injection. Car died on road. Started for about 15 sec. The next morning, but then nothing. The starter cranks, but the car does not start. When I put switch to the on position, the Check engine light goes on for about 2 sec. Then turns off. Oil pressure and battery charge light stay on. I feel the main relay click once and again about 2 seconds later and I can hear the fuel pump for about 2 seconds too. I have jumped the service connector and got diagnostic code 15 on the CEL light, but have since reset the ECU by pulling the Backup fuse for 10 seconds. Now when I jump the connector the CEL light stays on, but there is no code being blinked. I have checked all the fuse boxes, the main relay, the MAP sensor, the EGV sensor, the throttle angle sensor, Autozone checked the coil, and it was OK. Help please!
SPONSORED LINKS
Thursday, November 29th, 2007 AT 10:06 PM
