1988 Ford Thunderbird Runs fine for a while then dies
SEARCYRDSRDS
  • 1988 FORD THUNDERBIRD
  • 4 CYL
  • MANUAL
  • 210,000 MILES
I have a 1988 Ford Thunderbird Turbo Coupe. It will run fine for a while then it just dies completely. What could be causing this problem?
Friday, May 14th, 2010 AT 8:04 PM
  • 109,758 POSTS
First, neat car. I don't see them very often anymore. Regardless, does the car start right back for you when it dies? Has the check engine light come on? If it doesn't start right back up, have you checked to see if spark or fuel is missing to the engine?
Saturday, May 15th, 2010 AT 10:28 PM
SEARCYRDSRDS
The car don't start right back. Usually if it sits long enough to cool off it starts back. The check engine light is not on. Could this be a result of a faulty ignition module or ignition coil getting to hot?
Monday, May 17th, 2010 AT 9:26 AM
SEARCYRDSRDS
This is Ricky, I have the 88 Turbo Coupe that you replied to. The car don't start right back, but usually if it sits long enough to cool off it will start back. Could this be a result of a faulty ignition module or ignition coil that is getting to hot?
Monday, May 17th, 2010 AT 9:31 AM
  • 109,758 POSTS
Yes, it could be that. However, before you start replacing parts, check to see if the engine is getting spark and fuel when it doesn't start. If it has spark, then the module is good and there is a fuel problem.
Let me know what you find.
Monday, May 17th, 2010 AT 10:37 AM
