Coolant Leak?
AL0625
  • 1999 FORD TAURUS
1999 Ford Taurus 6 cyl Front Wheel Drive Automatic 167k miles
Had the coolant system flushed out and about a month after the waterpump went out. I replaced the waterpump and filled the system per owners manual. Since, the 'LOW COOLANT' light remains on. The tempature gauge is not showing it is running hot. What can I do?
Sunday, February 17th, 2008 AT 11:08 AM
MERLIN2021
  • 17,250 POSTS
The low coolant sensor is in the plastic recovery tank, new revised Ford fill procedure is fill cold to the hot line...this may help, if not the sensor will need to be swapped out!
Check this out
https://www.2carpros.com/articles/car-is-leaking-coolant
It can help you get the problem fixed.
Sunday, February 17th, 2008 AT 11:11 AM
