HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Taurus
Engine
Symptoms
Not Running
1996 Ford Taurus
NANNYP
MEMBER
1996 FORD TAURUS
1996 Ford Taurus
car will start but after driving it it wont start again, but after it sits for awhile it cranks up fine
Wednesday, June 10th, 2009 AT 10:37 PM
MECHANIC
Has the check engine light come on? Also, you need to check for spark and fuel when it won't start. One will most likely be missing.
Here are the how to's for checking.
https://www.2carpros.com/how_to/how_to_test_an_ignition_system.htm
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Let me know what you find.
SPONSORED LINKS
Thursday, June 18th, 2009 AT 11:25 PM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
1996 Ford Taurus Sho Cranks But Will Not Start
I Have A 96 Sho That Cranks But Will Not Start. I Have Received Different Opinions On It Consisting Of Both Exhaust Issues And Possibly...
Asked by
cmax99
1996
FORD TAURUS
VIDEO
How to fix an engine that wont start
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
1996 Ford Taurus, Oil Light Flashing And Car Won't...
The Oil Light Suddenly Started Flashing, The Car Died And Now It Won't Start. The Car Does Have Oil In It.
Asked by
dgweg
1 ANSWER
1996
FORD TAURUS
1996 Ford Taurus Doesnt Start
I Have A 1996 Ford Taurus That Occasionally Doesnt Start. It Cranks Over But Doesnt Fire.I Have Had A Mechanic Hook A Computer To It And It...
Asked by
dazza6773
1996
FORD TAURUS
Car Won't Start I Am Getting Some Trouble Codes
If I Ground The Red Wire On The Fuel Injector It Will Start. What Does That Mean The Problem Is? Did Get A Po130 Code. 1996 Ford Taurus....
Asked by
CarolBaysinger
1 IMAGE
1996
FORD TAURUS
1996 Ford Taurus Second Restart Engine Fails To Start
Electrical Problem 1996 Ford Taurus 6 Cyl Two Wheel Drive Automatic 189k Miles I Have A 1996 Ford Taurus That Likes To Start And Run ...
Asked by
dwb3937dwb
1996
FORD TAURUS
VIEW MORE
SPONSORED LINKS
Crankshaft Sensor Replacement
Crankshaft Sensor Symptoms
Online car repair manuals
