1993 Ford Taurus 6 cyl Front Wheel Drive Automatic
car stalls for no reason when driving- starts again after sitting awhile. Seems to run better when the tank is completely full of gas but if I let it go down half way that's when it seems to stall. Is it a sensor problem? Is it possible the sensor is telling the car the tank is empty? Noone seems to be able to figure it out since the diagnostics point to so many different things. The car has only 80,000 original miles on it. If you can figure this out, I will donate accordingly.
SPONSORED LINKS
Friday, May 14th, 2010 AT 6:32 PM
