1998 Ford Ranger RUN OUT OF GAZ CANT START ENGINE
MARIOTREASUOTTAWA
  • 1998 FORD RANGER
  • 4 CYL
  • MANUAL
  • 250,000 MILES
I RAN OUT OF GAZ I PUT MORE IN BUT NOW IT DOSENT START IS THERE A PRIMER SWITCH OR MAYBE DIRT WENT IN THE HOSE CAUSE I RAN OUT THANK YOU
Sunday, March 9th, 2008 AT 8:11 PM
BLACKOP555
  • 10,371 POSTS
Sounds like you blew your pump, running out of gas is a good way to destroy a pump.
Sunday, March 9th, 2008 AT 9:43 PM
MARIOTREASUOTTAWA
I WILL LOOK AT PUMP BUT THE TRUCK STARTED COUPLE TIME BUT MOTOR DIES EVEN IF I PRESS THE GAZ PEDAL 1 TIME I GOT RPM TO 5 BUT DIED RIGHT AFTER
Sunday, March 9th, 2008 AT 10:12 PM
