1989 Ford Ranger not sure whats wrong
DARKALONEDESIRABLE
  • 1989 FORD RANGER
Engine Performance problem
1989 Ford Ranger 6 cyl Two Wheel Drive Manual
loses power when I step on gas
Tuesday, December 9th, 2008 AT 9:46 PM
BLACKOP555
  • 10,371 POSTS
Ou should try doing would be to check the fuel pressure to see if it within the limits needed 5 psi could make quite the difference when a sudden increase is needed. Try stepping the gas really fast and see if the pressure drops. The pump may be weak.
Sunday, December 28th, 2008 AT 12:05 PM
