1994 Ford Probe CAR STALLED AND WILL NOT RE-START
MNOONE
  • 1994 FORD PROBE
  • 4 CYL
  • MANUAL
  • 122,000 MILES
I was driving my car with no current problems before this. I was driving and whent to stop at a red light and the car stalled. I restarted the car and it went about 150 feet and it stalled again and will not start back up. I replaced the coil, wires, plugs and distributer cap and router. It still will not start. Can you please help with what it could be. Thank you.
Wednesday, February 10th, 2010 AT 3:58 PM
Do below to determine whether it's a fuel or spark problem:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Thursday, February 11th, 2010 AT 12:56 AM
