2002 Ford Mustang Won't start
TVH43
  • 2002 FORD MUSTANG
  • V8
  • 31,675 MILES
When I took the car out of storage it started right up. I shut the car off at the gas station it did not start up. It turns over fine seems like not getting any gas. I put a new gas fillter in it ran for about 5 min then started missing really bad then shut off. Could the gas fillter plug up that fast.
Wednesday, April 7th, 2010 AT 9:36 AM
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Thursday, April 8th, 2010 AT 7:10 AM
