2001 Ford Mustang Cranks won't fire
RZUREICK
  • 2001 FORD MUSTANG
2001 Ford Mustang 4 cyl Two Wheel Drive Automatic
Engine cranks when trying to start but will not fire
Sunday, March 7th, 2010 AT 4:57 PM
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Monday, March 8th, 2010 AT 3:44 AM
