1983 Ford Mustang can I put a 351 cleveland engine into my
DAVEMACK
MEMBER
1983 FORD MUSTANG
Engine Mechanical problem
1983 Ford Mustang V8 Manual
I have a 83 gt mustang with a 302 engine.. I want to know if I can take a 351 cleveland motor and put it into my car and take out the 302. Will this work?
Sunday, April 11th, 2010 AT 11:19 PM
BLUEOVALPOWER50
MEMBER
Yes, they are a small block based engine and you can use the windsor trans but you will most likely have to research the flywheel and harmonic balancer combo for proper application, if im not mistaken they sell the swap kit from either jegs/summit minus the flywheel/ harmonic balancer
