2001 Ford F-150 Will not go into second smoothly
DANIEL KLEIN
  • 2001 FORD F-150
  • V8
  • 148,000 MILES
Engine revs high before going into second after backing off the gas. Will go into neutral if you punch it to go into passing gear.
Monday, February 22nd, 2010 AT 3:03 PM
  • 109,758 POSTS
Does it slip when it hits second? Has the check engine light come on? Is the trans fluid clean and full?
My first guess is the trans control module (TCM).
Monday, February 22nd, 2010 AT 8:44 PM
