1999 Ford F-150 Help me!
CHRISTOPER PENA
  • 1999 FORD F-150
  • V8
  • 13,500 MILES
Recently hanged the heatercore on my 99' f-150. Besides unueing the a/c lines under the hood releasing all of the coolant everything went well. So I thought I started it up and it idles up an down. I give it gas and the rpm's drop. Why could I have done wrong?
Friday, September 17th, 2010 AT 10:17 PM
BMRFIXIT
  • 19,053 POSTS
You had replaced the heater core?
Disconnected the hoses under the hood and coolant went every where !
Check spark plugs wells if full of coolant
did you disconnect the battery?
If so clean throttle body and IAC valve
Saturday, September 18th, 2010 AT 6:05 AM
CHRISTOPER PENA
Yes it went everywhere In the engine bay. I thought it could have gottan a few electrical components wet. I'll check the spark plug. I did disconnect the battery which later died left offshore and sat for three weeks so had to buy a new one. One more thing is there any truth to the myth that the cig lighter has smething to do with the computer or the way it idles? Becuase I did hook up the cig lighter back in after who knows how long. It was removed befor I bought the truck.
Saturday, September 18th, 2010 AT 8:42 AM
BMRFIXIT
  • 19,053 POSTS
When battery is disconnected, vehicle computer and memory systems may lose memory data.
Driveability problems may exist until computer systems have completed a relearn
Cigarette lighter and PCM
OBDII and cigarette light share the same fuse or power source
and no other
cigarette lighter should have no effect on the PCM and its operation
Saturday, September 18th, 2010 AT 7:51 PM
