HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
F-150
Engine
Symptoms
Revs Up
1990 Ford F-150 oil pressure
JEFFKOCH
MEMBER
1990 FORD F-150
V8
4WD
MANUAL
170,247 MILES
Oil pressure is good when cold. After warm pressure will drop if rpm under 1200
Friday, March 6th, 2009 AT 2:16 PM
BLACKOP555
MECHANIC
Try different viscosity oil, try going with a thicker kind.
If that isnt it thread in a oil pressure check guage and then check the oil pressure. A good rule of thumb is 10 psi per 1000 rpms.
SPONSORED LINKS
Sunday, March 8th, 2009 AT 12:32 PM
Please
login
or
register
to post a reply.
Related Engine Revs Up Content
1990 Ford F150 Truck Starts Up And Idles But Dies...
The Truck Starts Up Just Fine And Will Idle Nicely, Yet When The Gas Pedal Is Pushed, The Engine Dies Unless You Feather It. When Able To...
Asked by
brianwollam
1 ANSWER
1990
FORD F-150
GUIDE
Idle Air Control Motor Replacement
The idle air control motor or idle speed control motor is designed to adjust the air flow into the intake manifold at engine idle. Engine idle speed is monitored by the PCM...
1990 Ford F150 Noise Coming From The Rear Of The...
I Am Hearing A Noise Coming From The Rear Of My Truck When I Accelerate And Decelerate And When Im Reverse But It Doesnt Happen When I Put...
Asked by
fordtruckboy
1 ANSWER
1990
FORD F-150
1990 Ford F-150 Won't Stay Running
I Jumped My Truck And It Started But It Wouldnt Stay Running. I'd Have To Rev It To Keep It Going Any Further, But When I Let Up It Dies...
Asked by
WillDaBeast
1 ANSWER
1990
FORD F-150
2001 Ford F150 Engines Hesistates At 1700 Rpms To...
My Truck Hesistates At 1700 Rpms To 2200 Rpms. I Used To Have Codes Po171 And Po174. But Fixed Them By Replacing The Tps. Also In The...
Asked by
mnovelli
1 ANSWER
2001
FORD F-150
2006 Ford F150 Engine Rpms To Low
Hello, My F150 Has Started Doing Something Funny Every Now And Then When I Approach A Stop. Just Before The Vehicle Comes To A Complete...
Asked by
rivalidol
1 ANSWER
2006
FORD F-150
VIEW MORE
SPONSORED LINKS
Vacuum Leak Test and Repair
Vacuum Leak Symptoms
Online car repair manuals
