1994 Ford Escort wont start
MRIEDNER1982
  • 1994 FORD ESCORT
Engine Mechanical problem
1994 Ford Escort 4 cyl Front Wheel Drive Manual
I just had a new battery put into my car last friday, now my car wont start again. It turns over, and attempts to start but then dies out and the "fuel Output Cutoff" light comes on. What does this mean and why wont my car start now?
Friday, December 19th, 2008 AT 10:53 AM
MRIEDNER1982
I've checked the reset switch in the trunk of my car and it still will not start. Does this mean that I have blown the fuel pump, or something else? I was rocking it, flooring it, etc. For over an hour this morning due to a bad snowstorm, so this makes sense but if it its not fixing the issue by reseting the switch, what is the next thing to try?
Friday, December 19th, 2008 AT 11:23 AM
DOCFIXIT
  • 18,828 POSTS
Need to determine if it is fuel, ignition or mechanical.
Check for spark
Spray carb cleaner in throttle bodyIs engine spinning over faster than normal?
Friday, December 19th, 2008 AT 12:55 PM
MRIEDNER1982
I don't know how to do this. I am the ultimate woman when it comes to cars, so my knowledge is extremely limted:) how do I know if its sparking? If that means its trying to start, then yes it is. It tries to start and almost gets there, but then just dies out within seconds. And the engine spinning faster? No clue, doesn't SOUND any different than usual when I try to start it, if thats what you mean? I'm sorry:)
Friday, December 19th, 2008 AT 1:04 PM
