Hello, I can't tell if there might be an issue with your theft system? Did you check the circuits at the starter relay? As far as the scanner, check voltage at pin 16, datalink connector, should be hot all the time, if not check fuse 24--15 amp underhood fuse-box.
SPONSORED LINKS
Monday, August 17th, 2009 AT 10:54 AM
