1996 Ford Contour will start but does not hold RPMs
JEREMYB123
  • 1996 FORD CONTOUR
  • 6 CYL
  • FWD
  • 173,000 MILES
I have a 96 ford contour 2.5, it will start but I have to keep my foot on the gas, and once I let off it dies, I have have my spark plugs replaced and my vacuum hose, What could cause that? And it is louder then usual under the cars cabin.
Monday, January 26th, 2009 AT 4:49 PM
BMRFIXIT
  • 19,053 POSTS
Most likely you have a vacuum leak need to check it
check idle air control valve clean and or replace
Tuesday, January 27th, 2009 AT 5:33 PM
TAMMYBROWN28
  • 7 POSTS
Check the wiring connecting to alternator to the battery. I had that problem. If you touch the wiring, it'll crumble in your hands. So, that wiring may need to be replaced.
Monday, March 30th, 2009 AT 8:32 PM
