Engine compatibility years
STEVE W.
  • 13,505 POSTS
Most of the better parts stores will usually have them on the shelf. Just be sure it's one for fuel and not AC or tires.
Monday, April 26th, 2021 AT 2:24 PM
REGALDAVE
  • 15 POSTS
So I put in a remanufactured engine in my truck after a broken rod took out the old engine, I'm now getting a lot of blue smoke from this new engine after it has warmed up under load and idle. What should my next step be?
Saturday, May 1st, 2021 AT 4:27 PM
STEVE W.
  • 13,505 POSTS
I would contact the company that you got it from first, doing anything else could void any warranty on it. It might just need to be run hard a bit to get the rings to seal but they should be able to advise you. Then do what they say first. If that doesn't work tell them and return here.
Saturday, May 1st, 2021 AT 6:30 PM
