It starts but will not stay running after I let off the pedal?
HEMICHARGER73
  • 2002 DODGE RAM
I have an 02 Dodge Ram, it starts but will not stay running after I let off the pedal. I recently ran the battery dead and had to jump start it, after jumping it is when this problem started.
Saturday, July 17th, 2010 AT 7:33 AM
MERLIN2021
  • 17,250 POSTS
Have you replaced the battery and tested the charging system? The computer needs 9-10 volts to operate normally, and if the battery/alternator arent up to supplying the power, this can happen. When you jump started it, you didn't reverse the cables by mistake did you?
Saturday, July 17th, 2010 AT 8:36 AM
