When I make a turn, especially a right turn, the vehicle makes a loud rubbing sound.
Thursday, September 16th, 2010 AT 4:36 PM
BMRFIXIT
MECHANIC
Should have it checked as sounds and noises need to be heard and checked to get the best result
you can check the tires and inner fender cover
check tires if the correct size, tire size usually printed on driver door jam
jack tire up and check front end and check tires
if all checked OK
check drive shaft and u joints
good luck
