1999 Dodge Ram
SUEMAR
  • 1999 DODGE RAM
1999 Dodge Ram
my truck shut off while running
Wednesday, September 22nd, 2010 AT 12:04 AM
  • 109,758 POSTS
Has the check engine light come on? Have you checked fuel pump pressure?
Wednesday, September 22nd, 2010 AT 12:14 AM
SUEMAR
  • 11 POSTS
Sorry I couldnt get back to you sooner. Well no the check engine light doesnt come on and we took it to three machanice and they dont really know what it could be. One thinks it is the computer system and the other thinks it is the alarm wiring.
Sunday, October 10th, 2010 AT 10:10 AM
SUEMAR
  • 11 POSTS
How do I check the fuel pump pressure?
Sunday, October 10th, 2010 AT 10:15 AM
  • 109,758 POSTS
Hi:
Here is a how to for checking fuel pressure. It contains a video and also discusses checking the fuel pressure regulator which is easy to do.
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
As far as the security system, are you getting spark to the engine? Is it a factory alarm? Finally, is there a secruity light staying on?
NOTE: You will need a fuel pressure gauge. Most parts stores will lend or rent them to you. Let me know what you find.
Sunday, October 10th, 2010 AT 10:46 PM
SUEMAR
  • 11 POSTS
No I dont think its a factory alarm. Iam pretty sure the owner before us installed it with someone. So this is what we did we checked the fuel pressure and it was ok. Then we took it to pep boys to see it they could find the problem but they couldnt diagnose the problem it passed all test and no codes or fire shoot were found. To them the truck was fine. I dont know what else to do
Thursday, November 4th, 2010 AT 9:54 PM
SUEMAR
  • 11 POSTS
Also the starter and alternater was checked and they were fine as well.
Thursday, November 4th, 2010 AT 9:58 PM
  • 109,758 POSTS
If I had to guess, I would say you have a bad crank sensor. It should have set an engine light, but it doesn't always happen. When they checked it, it may have been working properly. Thus, they found no problem.
I hate to say it, but this is one of those problems that is either a guessing game, or the vehicle is used until the problem gets bad enough to find. However, based on your discription, it could be a hazard if the engine dies while driving.
You may want to try replacing the crank sensor to see if that fixes the problem, but I am going from experience only. There is nothing indicating that is 100% the problem.
Thursday, November 4th, 2010 AT 10:29 PM
SUEMAR
  • 11 POSTS
Ok where exactly will I find the crank sensor on my truck. I know the first machanic change something that look like the crank sensor I know that was on the left side (passager side) towords the bottom of the motor. Do u think the fuel system is giving out?
Sunday, November 7th, 2010 AT 9:24 PM
  • 109,758 POSTS
The crank sensor is near the harmonic balancer (bottom front of the engine). Make sure that hasn't already been replcaed. As far as the fuel system, it could be a weak fuel pump, regulator. Have you checked it? I believe I gave the directions in a prior posting.
Monday, November 8th, 2010 AT 8:50 AM
SUEMAR
  • 11 POSTS
Ok yeah that machanic did change the crank sensor and yeah we did check the fuel pressure I even think they checked it again at pep boys.
Monday, November 8th, 2010 AT 10:14 AM
  • 109,758 POSTS
I reviewed the entire post. Has the vehicle started since it died? If not, have you checked to see if you have spark and fuel to the engine?
Monday, November 8th, 2010 AT 10:21 AM
SUEMAR
  • 11 POSTS
Yeah the truck starts but then it dies. We never know when its going to die. It just happen the truck can be parked and turned on or while driving. Sometimes when it dies we need to wait about 5 to 20 min to start again but usually it start right back up like nothing. Everything else stays on like the air conditioning, radio, and lights. I dont know what it could be
Monday, November 8th, 2010 AT 11:05 PM
  • 109,758 POSTS
It is hard to say without a check engine light. However, a crank sensor usually plays a role in this type of situation. What you need to do is check for spark and fuel to the engine when this happens and it doesn't restart right away. One will be missing. Once we know which one is missing, then we know what system to attack, ignition or fuel. Do you know how to check for both items?
Tuesday, November 9th, 2010 AT 10:29 AM
SUEMAR
  • 11 POSTS
No how do I check for both items
Tuesday, November 9th, 2010 AT 11:25 AM
SUEMAR
  • 11 POSTS
Did u get my last message? How do I check for both items?
Monday, November 15th, 2010 AT 5:43 AM
Related General Content
