The problem is at idle it stalls as long as its in drive its ok?
EDWARD OBOYLE
  • 1996 DODGE RAM
  • V12
  • 4WD
  • 150,000 MILES
The listing does not give an option for V10 engine I have a dodge ram 2500 V10 4wd the problem is at idle it stalls as long as its in drive its ok only when I put it in park or neutral it stalls out the rest of the time it runs perfect
thanks for your help
ED
Monday, December 15th, 2008 AT 2:24 PM
RACEFAN966
  • 5,029 POSTS
Ok do you have a digital multi meter? What we need to do is a couple of tests one on the TPS and the other on the IAC motor. The Idle Air Control (IAC) motor requires a scan tool to test so that should be done at a shop unless you have access to on get back to me on that one.
Now on the TPS or throttle possition sensor that is different. You will need to back probe and you can use a paper clip to do that, the orange and dark blue wire. Now with key on engine of throttle at rest you should read between.8 to 1 volt. Now slowly lift the throttle till you get to wide open it should slowly and steadly increase to 4.5 to 5 volts with no glitches or drops. Let me know what you find ok. Thanks for your support.
Monday, December 15th, 2008 AT 5:31 PM
