Have a mechanic look at it before it goes up in flames with you inside!
In particular, they should look at the plastic fuel rail on the engine. They had a tendency to crack on older models. There was a repair kit for that and possibly a recall. That was long before 1999 though.
There was also an issue with the rubber o-rings on the injectors leaking. I never did one of those repairs so I don't know if there was a recall or service bulletin involved.
It's a little too new, but if you live in one of the salt belt states like Wisconsin, suspect rusted and leaking connectors on the fuel filter on the right frame rail under the car. You should be able to see a puddle on the ground.
Any fuel leak will result in lower than normal fuel pressure and a severe running problem. Normal is 45 - 50 pounds of pressure. Lucky you don't have a GM car. A drop of five pounds of pressure will result in a no-start condition. Chryslers will still run at ten pounds low, but they will run poorly.
Caradiodoc
SPONSORED LINKS
Wednesday, October 21st, 2009 AT 4:38 AM
