1998 Dodge Intrepid
SVANG87
  • 1998 DODGE INTREPID
  • 6 CYL
  • 111,135 MILES
HI, I DRIVE A 1998 DODGE INTREPID V6 3.2L, IT'S BEEN 3 MONTHS AND I'VE BEEN HAVING A PROBLEM. WELL. SAY I DRIVE THE CAR FOR 25-30 MINS THEN STOP BY A GAS STATION OR WHERE EVER. I TURN THE CAR OFF FOR 5-10 MINS COME BACK TURN IT BACK ON AND IT WON'T START. IT CRANK BUT WON'T START. I WILL SIT THERE FOR 25-30 MINS THEN IT START. I JUST REPLACE THE CAMSHAFT SENSOR AND THE CRANKSHAFT SENSOR BUT THAT'S NOT THE PROBLEM WHAT'S CAUSING. IT'S STILL ACTING UP CRAZY. WHAT'S THE PROBLEM WITH THIS? ANY IDEA?
Wednesday, January 7th, 2009 AT 8:05 PM
OBXAUTOMEDIC
  • 3,711 POSTS
Is your check engine light on? If so go by your local auto zone and have them pull codes, post them here in forum. If engine light not on have you ever changed the fuel filter. A clugged fuel filter can cause your problem, as your vehicle sits the debri in the filter will settle once settled vehicle will start and run until debri gets sturred up and clugs filter again.
Wednesday, January 7th, 2009 AT 8:10 PM
