Hello, Have you tried using a jump-box? Some of the national brand autostores will make house-calls. I don't know what they charge, you can call and ask? Maybe you just need a boost? If the battery is down, you need to take it off and have it recharged.
I'd have to make sure the battery has a full charge, around 12.6 volts. You need to be sure, the battery connections are clean and tight on both ends.
If the starter won't even crank, I'd test the starter relay circuits, the relay is in the power distribution center under the hood.
SPONSORED LINKS
Wednesday, August 12th, 2009 AT 1:15 PM
