1995 Dodge Intrepid Won't Start
DEADDODGE
  • 1995 DODGE INTREPID
  • 6 CYL
  • FWD
  • 136,000 MILES
My 95 Dodge Intrepid engine will crank, but.A) won’t start b) no spark b) no power at the fuel pump, c) the fault codes won't flash (but check engine light works) d) relays and fuses all check ok. E) Checked connections at battery, PCM, fuel pump, etc. F) checked continuity in fuel pump wiring and is ok. So what do you think the problem is?
Sunday, March 15th, 2009 AT 11:57 AM
JDL
  • 16,098 POSTS
Hello, the computer controls the asd relay and fuel pump relay on the same ground circuit. If there is no ground, those relays won't work.
Did you check for primary voltage at the coil pack and injectors, engine cranking? The asd relay supplies voltage to both.
I believe the computer has to see the proper cam and crank signals or it won't ground those relays. You can check the sensor circuits.
Sunday, March 15th, 2009 AT 1:24 PM
