1998 Dodge Durango won't start
JAKS69
  • 1998 DODGE DURANGO
  • V8
  • 4WD
  • 102,000 MILES
I have a 98 durango with a 5.2L, after the battery died on this vehicle I put a charger on start and tried to start it. To no avail the vehicle would just turn over and not fire. I replaced the crankshaft position sensor and now have 12v pulsing as it cranks to the coil but when I crank it with a plug pulled I get no spark. And it does not attempt to fire. I jumpered out the Auto Shut Down relay and also checked contnuity thru the wire, appears good. I am confused on having voltage to the coil but no spark, is it the PCM or Coil pickup in the distributer?
Wednesday, June 10th, 2009 AT 11:21 AM
JDL
  • 16,098 POSTS
Hello, if the coil wire goes to the cap, unplug the wire from the cap, hold close to engine ground, have helper crank engine, see if spark jumps from the coil wire. If it does, I think the problem is the rotor or cap.
Wednesday, June 10th, 2009 AT 12:24 PM
JAKS69
I unplugged the coil wire layed it near a ground extending the probe out, cranked it over. No spark
Wednesday, June 10th, 2009 AT 4:26 PM
JDL
  • 16,098 POSTS
Take the primary connector, smaller wires, loose from the coil. Use an led testlite between the terminals on the connector, engine cranking, there should be a pulse.
With the engine cranking, check for voltage at the injectors.
Thursday, June 11th, 2009 AT 8:39 AM
