Few thinks not adding up here
if no check engine light on, PCM (the brain )not being powered and I can not see the OBDII reader communicating with a dead brain to give you no codes
with key on you should have check engine light on
if not check fuses and ignition switch
very possible to be a wiring
and you may be in need for wiring schematic
have your man check if ignition switch working the way it suppose to be
good luck
Monday, October 5th, 2009 AT 8:42 PM
