1997 Dodge Caravan takes 3-4 tries before engine will start
STEPHI67
  • 1997 DODGE CARAVAN
  • 6 CYL
  • FWD
  • 130,000 MILES
Battery good, takes 3-4 tries before engine will crank.
Sunday, June 27th, 2010 AT 3:17 PM
Check and test the coolant temperature sensor, idle air control motor and throttle position sensor could also be the ignition switch or the ASD relay acting up-also check the fuel pressure
Sunday, June 27th, 2010 AT 4:41 PM
