1997 Dodge Caravan Normally starts but not always
TEXANLOSTINSD
  • 1997 DODGE CARAVAN
Electrical problem
1997 Dodge Caravan Two Wheel Drive Automatic
I have a 1997 Dodge Caravan that normally starts, but on occasion, for no apparent reason it won't start. You never know when it will do this. 99.9% of the time it works just fine. Any Ideas?
Sunday, February 28th, 2010 AT 4:53 PM
BMRFIXIT
  • 19,053 POSTS
If no crank suspect a bad starter
Sunday, February 28th, 2010 AT 9:48 PM
HAHNY1
  • 75 POSTS
If no crank it could be the starter or it could also be the battery, make sure the cables are clean and tight. On my 94 they were pretty snug but still caused the problem. Another possible is the ignition switch but I would say this is probably least likely
Saturday, March 6th, 2010 AT 7:22 PM
