IM TRYING TO TAKE OFF THE OLD STUDS FROM THE FRONT DRIVER SIDE AND I DONT HAVE A IDEA WHERE TO START I NEED HELP
Monday, March 3rd, 2008 AT 6:57 PM
MASTERTECHTIM
MECHANIC
Do you mean the wheel studs? I think those you can just beat out and install new ones, or you might have to loosen up the hub bearing by removing the axle nut then remove the brakes and loosen the hub retaining bolts and pry hub out a little then they will come out and go in.
