98 Chevy won't start. Fuel Pump replaced 2 yrs ago. Engine will rotate, rotate, won't turn over. Battery checked, said was fine. I do not hear fuel pump whine when turn ignition on, I checked relay under hood, I feel it clicking when key turned on. I have spark at plugs, I have not checked fuel filter as it was replaced about 3 months ago. I have been adding octane booster now and then for last couple months. Does it sound like fuel pump? I do not know where to check to see if pump getting voltage, nor do I have fuel pressure check. I should hear pump buzzing when key turned on right?
SPONSORED LINKS
Sunday, May 11th, 2008 AT 12:35 AM
