1998 Chevy Truck Engine won't start
RAY62551
  • 1998 CHEVROLET TRUCK
  • V8
  • 4WD
  • 205,000 MILES
The starter went out and after replacing it the engine turns over fine but won't start. I have fire at the plugs and good fuel preasure.
Monday, January 4th, 2010 AT 3:48 PM
Did you determine the fuel pressure with a fuel pressure gauge or just the thumb or eyeball method if it is, its not gonna work-you need to check it with the gauge, also valve and ignition timing could be off-Injector/s might not be pulsing.
Monday, January 4th, 2010 AT 4:46 PM
